Could have been helpful to share what type of AC system you plan on using, but either way I think you can do the following:
- Set the zone Thermostat's cooling temperature to 26°C
- Use an AvailabilityManager:HighTemperatureTurnOn to sense the Outdoor Air Temperature with a temperature setpoint of 29°C.
This would look like the following, making sure you replace the 'Sensor Node' by a valid Outside Air node
AvailabilityManager:HighTemperatureTurnOn,
AC HighTemp Turn On Availability Manager, !- Name
Outside Air Inlet Node, !- Sensor Node
29.0; !- Temperature {C}
Package the
AvailabilityManager:HighTemperatureTurnOninto an AvailabilityManagerAssignmentListUse this assignment list into your zone air conditioner. For example, if you use
ZoneHVAC:PackagedTerminalAirConditioner, you would put it into the Availability Manager List Name
