Here is the documentation for the SiteGroundReflectance class (not the "Site_GroundReflectancefields" class, which is something different).
The setJanuaryGroundReflectance (etc.) methods should work to set the ground reflectance by month.
Here is the documentation for the SiteGroundReflectance class (not the "Site_GroundReflectancefields" "_fields" class, which is something different).
The setJanuaryGroundReflectance (etc.) methods should work to set the ground reflectance by month.month.
