To run algorithms locally, you will need to setup your own OpenStudio Server. You have 2 options here:
checkout https://github.com/NREL/OpenStudio-server locally and build your own Docker containers.
use the already built docker containers and do the following:
docker pull nrel/openstudio-server:2.1.1
docker pull nrel/openstudio-rserve:2.1.1
docker pull mongo
docker volume create --name osdata
Once the containers are spun up, use docker-compose with the .yml file located here and then from that folder run
docker-compose up
to add workers:
docker-compose scale worker=44
here: 1. checkout https://github.com/NREL/OpenStudio-server locally and build your own Docker
containers.containers. 2. use the already built docker containers and do the following:
docker pull mongo
docker-compose up
to add workers:
To run algorithms locally, you will need to setup your own OpenStudio Server. You have 2 options here: 1. checkout https://github.com/NREL/OpenStudio-server locally and build your own Docker containers. 2. use the already built docker containers and do the following:
docker pull
docker pull
mongo
mongo
run docker-compose up
to add workers:
