You should be able to go to "File->Load Library" and choose and OSM file. Then on the "Schedule Sets" or "Schedules" tab you can click on the "Library" tab (next to "My Model"). From there you can drag schedule sets or schedules in to your model. This worked for me in my limited testing, if you are having trouble with that workflow then I wonder if it is an issue related to your specific OSM not seen in the ones I am testing? If you don't mind sending the file you are importing from to OpenStudio@nrel.gov along with the name of the schedule you are trying to import we'll take a look.
