From the engineering reference...
$$Q_{toair} = H_{fan} + (H_{motor} - H_{fan}) * f_{motortoair}$$
While not discussed in the fan section, I assume it's the same logic as pumps. Any shaft power is eventually realized as heat to the fluid due to friction losses. I'm not actually a fan of that because in the real world, you're not controlling to those losses because that heat would be added after any kind of discharge air controller.
While not discussed in the fan section, I assume it's the same logic as pumps. Any shaft power is eventually realized as heat to the fluid due to friction losses. I'm not actually a fan fan of that because in the real world, you're not controlling to those losses because that heat would be added after any kind of discharge air controller.
