PTAC: Packaged Terminal Air Conditioner (Cooling Only)
PTHP: Packaged Terminal Heat Pump (Heating and Cooling)
Don't know why it's lower without looking at the inputs you're using. You can compare the wrapped object inputs to see what's different between the two.
OS Default Curves for Coil:Cooling:DX:SingleSpeed in PTAC and PTHP
Total Cooling Capacity - Function of Temperature
Total Cooling Capacity - Function of Flow Fraction
EIR - Function of Temperature
EIR - Function of Flow
Part Load Fraction - Function of Part Load Ratio
Don't know why it's lower without looking at the inputs you're using. You can compare the wrapped object inputs to see what's different between the two.using.
PTAC: Packaged Terminal Air Conditioner Conditioning (Cooling Only)
