The problem is that the Sky Diffuse Modeling Algorithm
of ShadowCalculation is changed automatically by EnergyPlus.
** Warning ** GetShadowingInput: The shading transmittance for shading devices changes throughout the year. Choose DetailedSkyDiffuseModeling in the ShadowCalculation object to remove this warning.
** ~~~ ** Simulation has been reset to use DetailedSkyDiffuseModeling. Simulation continues.
** ~~~ ** Better accuracy may be gained by setting the Calculation Frequency to 1 in the ShadowCalculation object.
This happens in SolarShading.cc#L675.
There is a Github Issue that seems relevant here.
Shorten runtime?
I have set the Calculation Frequency
to be 30 days (calc method set to AverageOverDaysInFrequency
) instead of 7, runtime went down to 10 minutes.
Shorten runtime?
to be 30 days (calc method set to AverageOverDaysInFrequency) instead of 7, runtime went down to 10 minutes.AverageOverDaysInFrequency
Shorten runtime?I haven't found a way to shorten the runtime.
of ShadowCalculation model is changed automatically by EnergyPlus.
