I'd be interested in hearing from the developers regarding why this occurs, but a solution I've found is to subdivide the floor surface so that the 'subsurface' is not surrounded by a single larger surface by more than two edges:
You end up with more surfaces for the space, but they remain surfaces when intersected/matched.
