To create the idf file name.csv file that contains the OutputVariables I use these steps in OpenStudio:
- Select built in variable(s) from the Output Variable tab OR copy the variable name verbatim from the
eplusout.rddfile to the Add Output Variable measure - Run the OSM or OSP file and then run the resulting
out.idfthrough EnergyPlus which will create theout.csvfile containing the variables.
