Thanks, this works. Im just wondering for my own curiosity, why would surfaces not be matched when you use the OS function to 'Create a Standard Building Shape'. I do understand that if you are hand drawing internal partitions, you need to make the extra step to match surfaces, but when you create a standard building, it seems like it would be 'almost' ready to simulate (e.g. only zoning is needed).
Is there a reason to have unmatched internal partitions, for instance, does that offer you more flexibility?
