You have two options here.
  1. If using OpenStudio, we have an electric clothes dryer measure that you can use. The inputs for the measure can be obtained from the BEopt heat pump clothes dryer option (which were provided by FSEC).
  2. If using EnergyPlus, you could run two simulations in BEopt (one with no clothes dryer and one with the heat pump clothes dryer), diff the two EnergyPlus IDF files, and add the necessary objects to your file.
Note: The energy use of a clothes dryer is strongly tied to what clothes washer is used (and hence, the remaining moisture) as well as the number of bedrooms (which dictates number of drying loads). In both options, you'll want to specify these appropriately.
Note: Clothes dryer venting is not as straightforward. We currently handle it in BEopt as part of a larger EMS-based routine that incorporates interactions of infiltration, ventilation, and duct leakage. We're hoping to switch over to Airflow Network longer term. The way that you model dryer venting will be specific to how you are already modeling airflow in your EnergyPlus model.
  2. If using EnergyPlus, you You could run two simulations in BEopt (one BEopt, one with no clothes dryer and one with the heat pump clothes dryer), dryer, diff the two EnergyPlus IDF files, and add the necessary objects to your file.
