I got this to work via separate Python code that:
- Creates a library of skies with
gendaylitfor all the hours in the weather files I'm looking at. - Makes an octree using
oconvwith the appropriate sky and themodel.radandmaterials.radgenerated by OS/Radiance only if the sun is within view of the window (by azimuth) - Makes a fisheye HDR image with
rpictand that octree and the parameters from the glare sensor files generated by OS/Radiance - Outputs the glare metrics using
evalglare
