The RunPeriod specifies the begin and end days for the simulation. In OpenStudio this object is referenced in the Simulation Settings tab.
I'm not aware of a way to specify the hours of the day so you may need to create a workaround for that using the other RunPeriod objects or postprocessing the output.
The RunPeriod specifies the begin beginning and end ending days for the simulation. In OpenStudio this object is referenced in the Simulation Settings tab.
The RunPeriod specifies the beginning and ending days for the simulation. In OpenStudio this object is referenced in the Simulation Settings tab.
The In OpenStudio the EnergyPlus object RunPeriod specifies the beginning and ending days for the simulation. In OpenStudio this object is referenced can be specified in the Simulation Settings tab.
