Try the "Merge Spaces from External Model" user script in the SketchUp Plugin. It is demonstrated in this video. You will have to re-match surfaces after merging geometry from one model to another.
You could also try the Create Baseline Model measure on BCL to create a baseline from your proposed model. We have a video for the baseline measure as well.
Try the "Merge Spaces from External Model" user script in the SketchUp Plugin. It is demonstrated in this videovideo.. You will have to re-match surfaces after merging geometry from one model to another.
