Earth Tubes are not directly supported in OpenStudio, but you can write IDF objects for the earth tube and add them in just before the simulation is run using the Inject IDF objects EnergyPlus measure.
If you will use this frequently it could be nice to have a custom measure that has arguments the earth tube and ground characteristics, as well as what zones to use earth tubes on.
