For the UnitarySystem, there is load and set point based control types. For load control you would use only a thermostat in the control zone. For set point control you would use a set point manager to place a set point at the coil outlets, and depending on what type of set point manager is used, you might also need the thermostat.
AirLoopHVAC:UnitarySystem,
  GasHeat DXAC Furnace 1,  !- Name
  Load,                    !- Control Type
