Ok, I may have come to a solution:
import os
from eppy.modeleditor import IDF
import sys
import math
from geomeppy import IDF
def make_adiabatic(c):
print('converting %s into adiabatic' %c)
c.Outside_Boundary_Condition = 'Adiabatic'
c.Sun_Exposure = 'NoSun'
c.Wind_Exposure = 'NoWind'
print('done\n')
# path to E+ idd file (required by eppy)
iddfile = os.path.join(sys.argv[4], 'Energy+.idd')
IDF.setiddname(iddfile)
# path to energyplus input file within each simulated folder
idf = os.path.join(sys.argv[2], 'in.idf')
# assigns reads parameter from jeplus
jeplus_floor = str(sys.argv[3])
# read idf file to eppy
idf = IDF(idf)
# Convert horizontal surfaces to adiabatic depending on the value of the jeplus parameter
floors = idf_New.getsurfaces('Floor')
ceilings = idf_New.getsurfaces('Ceiling')
roofs = idf_New.getsurfaces('Roof')
if jeplus_floor == 'Ground_Floor':
adiab_ceilings = make_adiabatic((c) for c in ceilings)
adiab_roofs = make_adiabatic((c) for c in roofs)
elif jeplus_floor == 'Top_Floor':
adiab_floors = make_adiabatic((c) for c in floors)
else:
I look forward to receive your feedback on this!
