Assuming you are talking about the Tables in the OpenStudio Results HTML file you can just open that in a web-browser outside of OpenStudio and copy the table and paste into Excel.
If you need to do this at scale you can write a measure to create CSV file instead of HTML. Also PAT2 has the ability to write project reporting scripts that can save high level data (runner.registerValues in measures) across all datapoints in an analysis.
