You are correct, OpenStudio only supports a subset of the ShadingControlTypes as EnergyPlus. If you set a field to an invalid value, you won't know it unless you specifically check it like this or echo the value back by getting what you just set.
var = object.setValue("SomethingBad")
if var == false
  puts "did not accept value"
end
The following Shading Control Types are supported by OpenStudio:
  • Always On
  • Always Off
  • OnIfScheduleAllows
  • OnIfHighSolarOnWindow
Here is a link to the types EnergyPlus supports.
I don't know if changing the IDD will work, it might, but an easier approach might be to alter the ShadingControlType with an EnergyPlus measure, as shown in the code snippet below. Because this happens after the OSM is translated to an IDF you have access to anything EnergyPlus supports.
workspace.getObjectsByType("WindowProperty:ShadingControl".to_IddObjectType).each do |shading_control|
  shading_control.setString(3,"OnIfHighZoneAirTemperature") # shading control type field
end
Feel free to add this as a feature request.
if var == false
end
  • Always On
  • Always Off
end
if var == false
end
The following Shading Control Types are supported by OpenStudio:OpenStudio: Always On Always Off OnIfScheduleAllows OnIfHighSolarOnWindow
  • Always On
  • Always Off
Here is a link to the types type EnergyPlus supports.
I don't know if changing the IDD will work, it might, but an easier approach might be to alter the ShadingControlType with an EnergyPlus measure, as shown in the code snippet below. Because this happens after the OSM is translated to an IDF you have access to EnergyPlus supports.
end
