You can select a shading control object to set the setpoints. See documentation for units
Shading control can be accessed in the OpenStudio application as well but optional fields will show up as light purple and can't be edited unless exposed by editing proper fields in plugin or with measure by setting a value. This is true for any object with optional fields.
