I assume you are talking about a air to air heat recovery wheel? If that is the case you will need to add the following to the supply equipment side of your air loop: - AirLoopHVAC:OutdoorAirSystem - Fan:ConstantVolume or FanVariableVolume - HeatExchanger:AirToAir:SensibleAndLatent - SetpointManager (there are several of these depending on the control you are looking for)
You will also need to assign an operation schedule under the control tab of the loop.
