You can't.
You have to request output at the Timestep level, which will give you in your case output at one-minute interval (60 timesteps per hour) and then do post-processing to get 30-min interval average / sum depending on the variable you're looking at (any consumption would be a sum, any rate would be an average)
You can't.
You have to request output at the Timestep level, which will give you in your case output at one-minute interval (60 (6° timesteps per hour) and then do post-processing to get 30-min interval average / sum depending on the variable you're looking at (any consumption would be a sum, any rate would be an average)
