You didn't tag which software you're using, but I'll assume it's rooted in EnergyPlus. You need to add the following Output:Variable object.
Output:Variable,
  ,                         !-Key Value
 Zone Mean Air Temperature, !- Variable Name
 Hourly;                    !- Reporting Frequency
Look at the *.rdd file in the E+ output directory of your *.idf for more variable names.
