Assuming you've cloned the EnergyPlus repository on GitHub, have you read through the Wiki there?
I believe you'll have to build EnergyPlus, although I have not done it myself. See the Building EnergyPlus documentation for instructions.
Assuming you've cloned the EnergyPlus repository on GitHub, have you read through the Wiki Wiki there?
Assuming you've cloned the EnergyPlus repository on GitHub, have you read through the Wiki there? I believe you'll have to build EnergyPlus, although I have not done it myself. See the Building EnergyPlus documentation for instructions.
