This error is related to a compatibility setting within MS Windows 7. To work around this, r-click the short-cut for eQUEST and select properties. Select the compatibility tab, check the box "Run this program in compatibility mode for:", and choose "Windows XP (Service Pack 3)" as the compatibility mode, allowing adequate permissions for the program to operate as intended.
