The eplusout.err file will have the specific cause of the error. Navigate to it inside the OpenStudio app (see image below) or through the OSM file directory: osm file name folder > run > 6-EnergyPlus-0 > eplusout.err
Open the ERR file and search for either "severe" or "fatal" errors, those will be the ones causing the simulation to fail.
I always use the Add Output Diagnostics measure and "DisplayAllWarnings" which provides more detailed descriptions of the errors.
Eplusout.err File Location
I always use the Add Output Diagnostics measure and "DisplayAllWarnings" which provides more detailed descriptions of the errors.any errors I encounter.
I always You can also use the Add Output Diagnostics measure and "DisplayAllWarnings" which provides will provide more detailed descriptions of any errors I encounter.the errors.
The eplusout.err file will have the specific cause of the error. Navigate to it inside the OpenStudio app (see image below) or through the OSM file directory: osm "osm file name folder folder" > run > 6-EnergyPlus-0 > eplusout.err
You can also use the Add Output Diagnostics measure and "DisplayAllWarnings" which will provide for more detailed descriptions of the errors.
The eplusout.err file will have the specific cause of the error. Navigate to it inside the OpenStudio app (see image below) or through the OSM file directory: "osm file name folder" > run > 6-EnergyPlus-0 > eplusout.err
You can also use the Add Output Diagnostics measure and "DisplayAllWarnings" for more detailed descriptions of the errors.
