maximum outdoor air flow rate (10.0000) < minimum outdoor air flow rate (11.0000)
* ~~~ * To set the minimum outside air flow rate use the "Design (minimum) outdoor air flow rate" field in the Sizing:System object
Bolded line appears to be your error. Your maximum OA flow is specified to be lower than the minimum specified OA flow.
Bolded line appears to be your error. Your maximum OA flow airflow is specified to be lower than the minimum specified OA flow.airflow.
