I would create a separate Electric Equipment Definition and a schedule for each one from the OpenStudio Loads tab. If you want to sub-meter these use the End-Use Subcategory field, which is not exposed in the OpenStudio app but can be set using the API. These will show up in the End Uses By Subcategory
table in the EnergyPlus HTML results file. Here's an example using elevators.
# get model objects
objs = model.getElectricEquipments
# do stuff
objs.each do |obj|
eed = obj.electricEquipmentDefinition
if eed.name.to_s.include?('Elevators')
obj.setEndUseSubcategory('Elevators')
end
end
# get model objects
# do stuff
objs.each do |obj|
puts eed
puts obj
end
end
I would create a separate Electric Equipment Definition and a schedule for each one from the OpenStudio Loads tab. If you want to sub-meter these use the End-Use Subcategory field, which is not exposed in the OpenStudio app but can be set using the API. These will show up in the Here's an example using elevators.End Uses By Subcategory
# get model objects
# do stuff
objs.each do |obj|
puts eed
puts obj
end
end
I would create a separate Electric Equipment Definition and a schedule for each one from the OpenStudio Loads tab. If you want to sub-meter these use the The ElectricEquipment End-Use Subcategory field, which field is not exposed in the OpenStudio app but app. However, it can be set using the API. Here's an example using elevators.
# get model objects
# do stuff
objs.each do |obj|
puts eed
puts obj
end
end
