Thanks Archmage, I tried both of your suggestions,
The first suggestion works but it is required to keep the thermostat to a high temperature and remove the bypass pipe.
I put a loadprofile:plant after the baseboard with zero load but controlling that object flow rate can not overwrite the base board flow rate.
The first suggestion worksthere is only one baseboard on the pump loop. When i keep the pump flow rate fixed, It caps the flow rate on baseboard to that value but itis requiredstill fluctuates between 0 and that value. Even if i try to keep the thermostatto avalue pretty high (like 50 c), that results in severe errors with crazy high temperatureand remove the bypass pipe.points.I put a loadprofile:plant after the baseboard with zero load but controlling that object flow rate can not overwrite the base board flow rate.
Do you think if i change from a zone equipment like baseboard to a heating coil which is controlled by a setpoint manager connected to the thermal zone, Would there be any chance that i can control its mass flow rate?
