The EnergyPlus 'lights' object allows for an end-use subcategory definition.
OpenStudio does not expose this input in the user interface, but it does exist in the API which means you can create a measure to set this value for certain definitions.
These categories will show up in the 'End-Uses By SubCategory' table in the E+ HTML output file.
