There is a lot in the OS application that is not "wired up" correctly to the Radiance measure; you just found one of them. Sorry about that. While we are working on getting the Radiance measure working correctly under OS 2.x as we speak, and when it's good to go it will be relocated to the BCL and usable starting with OS 2.1, all the work is to get the measure working with its current functionality. In other words, there are no plans to implement new features in the Radiance measure.
