Here are a couple workarounds, but I haven't tried them:
If there is just one baseboard on the plant loop you could actuate the pump's flow rate schedule to limit the flow available.
It might work to put a LoadProfile:Plant object on the same hot water branch in front of the baseboard's connection and actuate it's mass flow rate (with no load).
