After I wrote all this I realized it would be more efficient and scalable to go backward though the mixer rather than forward through the splitter. Oh well.
def airLoopThermalZones(workspace, runner, air_loop, zone_names)
    air_loop_name = air_loop.getString(0).get.to_s
    # splitters
    splitters = workspace.getObjectsByType("AirLoopHVAC:ZoneSplitter".to_IddObjectType)
    # terminals
    uncontrolleds = workspace.getObjectsByType("AirTerminal:SingleDuct:Uncontrolled".to_IddObjectType)
    cv_reheats = workspace.getObjectsByType("AirTerminal:SingleDuct:ConstantVolume:Reheat".to_IddObjectType)
    vav_reheats = workspace.getObjectsByType("AirTerminal:SingleDuct:VAV:Reheat".to_IddObjectType)
    vav_noreheats = workspace.getObjectsByType("AirTerminal:SingleDuct:VAV:NoReheat".to_IddObjectType)
    vav_hc_noreheats = workspace.getObjectsByType("AirTerminal:SingleDuct:VAV:HeatAndCool:NoReheat".to_IddObjectType)
    piu_series_reheats = workspace.getObjectsByType("AirTerminal:SingleDuct:SeriesPIU:Reheat".to_IddObjectType)
    piu_parallel_reheats = workspace.getObjectsByType("AirTerminal:SingleDuct:ParallelPIU:Reheat".to_IddObjectType)
    # adus
    adus = workspace.getObjectsByType("ZoneHVAC:AirDistributionUnit".to_IddObjectType)
    # equipment lists
    equip_lists = workspace.getObjectsByType("ZoneHVAC:EquipmentList".to_IddObjectType)
    # equipment connections
    equip_connections = workspace.getObjectsByType("ZoneHVAC:EquipmentConnections".to_IddObjectType)
    # required intermediate arrays
    adu_terminal_names = []
    other_terminal_names = []
    adu_names = []
    equip_list_names = []
    # get air loop inlet node list
    inlet_nodelist_name = air_loop.getString(8).get.to_s
    inlet_nodelist = workspace.getObjectByTypeAndName("NodeList".to_IddObjectType, inlet_nodelist_name).get
    # get air loop demand inlet node name
    node_name = inlet_nodelist.getString(1).get.to_s
    # find cooresponding splitter
    splitter = nil
    splitters.each do |splitter_temp|
        if splitter_temp.getString(1).get.to_s == node_name
            splitter = splitter_temp
        end
    end
    # store all splitter outlet node names
    splitter_outlet_node_names = []
    for i in 2..splitter.numFields.to_i-1
        splitter_outlet_node_names << splitter.getString(i).get.to_s
    end
    # find terminals that use stored splitter outlet nodes
    splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, other_terminal_names, uncontrolleds, 2, runner)
    splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, cv_reheats, 3, runner)
    splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, vav_reheats, 3, runner)
    splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, vav_noreheats, 3, runner)
    splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, vav_hc_noreheats, 3, runner)
    splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, piu_series_reheats, 5, runner)
    splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, piu_parallel_reheats, 6, runner)
    if splitter_outlet_node_names.size >= 1
        runner.registerError("There were #{splitter_outlet_node_names.size} that were not able to be matched to terminals for #{air_loop_name}.")
        return false
    end
    adus.each do |adu|
        adu_terminal_name = adu.getString(3).get.to_s
        adu_terminal_names.each do |air_terminal_name|
            if air_terminal_name == adu_terminal_name
                adu_names << adu.getString(0).get.to_s
            end
        end
    end
    equip_lists.each do |equip_list|
    i = 2
    length = equip_list.numFields.to_i
    while i < length
        equip_list_adu_name = equip_list.getString(i).get.to_s
        if adu_names.size > 0
            adu_names.each do |adu_name|
                if adu_name == equip_list_adu_name
                    equip_list_names << equip_list.getString(0).get.to_s
                end
            end
        elsif other_terminal_names.size > 0
            other_terminal_names.each do |other_terminal_name|
                if other_terminal_name == equip_list_adu_name
                end
            end
        else
            runner.registerError("No equipment able to be matched to air terminal names for #{air_loop_name}.")
            return false
        end
        i = i + 4
    end
end
if equip_list_names.size == 0
    runner.registerError("No equipment lists were able to be matched to air distribution units for #{air_loop_name}.")
    return false
end
    equip_connections.each do |equip_connection|
        equip_connection_equip_list_name= equip_connection.getString(1).get.to_s
        equip_list_names.each do |equip_list_name|
            runner.registerInfo("Checked #{equip_list_name} with #{equip_connection_equip_list_name}")
            if equip_list_name == equip_connection_equip_list_name
                zone_names << equip_connection.getString(0).get.to_s
            end
        end
    end
    if zone_names.size == 0
        runner.registerError("No zones were able to be matched to air loops for #{air_loop_name}.")
        return false
    end
    return zone_names
end
def checkTerminalNodeMatch(splitter_nodes, air_terminal_names, terminals, field, runner)
    #NESTED IFS END LIVES
    if splitter_nodes.size >= 1
        splitter_nodes.each do |splitter_node|
            # for uncontrolled terminals
            terminals.each do |terminal|
                if terminal.getString(field).to_s == splitter_node
                    air_terminal_names << terminal.getString(0).get.to_s
                    splitter_nodes -= [splitter_node]
                    runner.registerInfo("Found Match! Terminals Matched: #{air_terminal_names.size}, Splitter Nodes Left: #{splitter_nodes.size}.")
                    break
                end
            end
        end
    end
    return splitter_nodes
end
    # splitters
    # terminals
    # adus
    # equipment lists
    adu_names = []
    splitter = nil
        end
    end
    end
        return false
    end
    adus.each do |adu|
            end
        end
    end
    i = 2
    while i < length
                end
            end
                end
            end
        else
            return false
        end
        i = i + 4
    end
end
    return false
end
            end
        end
    end
    end
    end
end
     return false
    end
    end
return zone_names
end
end
                 break
                end
            end
        end
    end
    end
        end
    end
end
 end
 # splitters
 # terminals
 # adus
 # equipment lists
    adu_terminal_names air_terminal_names = []
    other_terminal_names adu_names = []
    adu_names equip_list_names = []
 splitter = nil
        end
    end
    end
end
    end
    end
 splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, other_terminal_names, air_terminal_names, uncontrolleds, 2, runner)
 splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, air_terminal_names, cv_reheats, 3, runner)
 splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, air_terminal_names, vav_reheats, 3, runner)
 splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, air_terminal_names, vav_noreheats, 3, runner)
    splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, air_terminal_names, piu_series_reheats, 5, runner)
 splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, air_terminal_names, piu_parallel_reheats, 6, runner)
     return false
    end
    end
adus.each do |adu|
        adu_terminal_names.each air_terminal_names.each do |air_terminal_name|
            end
        end
    end
    i = 2
    while i < length
        end
    end
end
if adu_names.size > == 0
                end
            end
                end
            end
        else
            runner.registerError("No equipment ADUs were able to be matched to air terminal names for #{air_loop_name}.")
     return false
        end
end
    i = 2
    while i < length
            end
        end
        i = i + 4
    end
end
    return false
end
        end
    end
end
    return false
end
return zone_names
end
                break
            end
        end
    end
end
end
