It is just plain ACII text, you should be able to open with any text editor, or if you use Windows, the notepad is good enough. You can also open with a spreadsheet program so you can make any calculations. Good Luck!
It is just plain ACII text, you should be able to open with any text editor, or if you use Windows, the notepad is good enough. You can also open with wit a spreadsheet program so you can make any calculations.
Good Luck!
