This doesn't answer your original question about referencing an object by name. However, I think you can sort of get what you want to do using this:
LIGHTING-W/AREA = (
{if(#P("POLYGON")==#SI("EL1 Floor Polygon", "FLOOR","POLYGON"))then
1.0
else if (#P("POLYGON")==#SI("EL2 Floor Polygon", "FLOOR","POLYGON"))then
0.5
else
no_default
endif
endif} )
This expression is based on the parent Floor Polygon U-name, rather than the parent Floor U-name. Additionally, you can't use an expression for "X" in the switch statement for "case X:", so you have to use a nested if-then instead which is messy. I have shown only two branches in my example, but you can greatly expand that. I don't know if there is a limit on number of nested if-then statements, or just a limit on number of characters for the user defined expression (I don't recall what that character limit is.)
This doesn't answer your original actual question about referencing an object by name. However, I think you can sort of get what you want to do using this:
LIGHTING-W/AREA = (
1.0
0.5
else
no_default
endif
endif} )
This doesn't answer your actual question about referencing an object by name. However, I think you can sort of get what you want to do using this:
LIGHTING-W/AREA = (
1.0
0.5
else
no_default
endif
endif} )
this:
LIGHTING-W/AREA = (
1.0
0.5
else
no_default
endif
endif} )
) This expression is based on the parent Floor Polygon U-name, rather than the parent Floor U-name. Additionally, you can't use an expression for "X" in the switch statement for "case X:", so you have to use a nested if-then instead which is messy. I have shown only two branches in my example, but you can greatly expand that. I don't know if there is a limit on number of nested if-then statements, or just a limit on number of characters for the user defined expression (I don't recall what that character limit is.)
