Problem cause:
There is an option in EP-Launch, I believe disabled by default, to allow more than 250 columns. In reality, it's actually 255 variables + one column header that gives 256 columns. So by default the CSV output generated by ReadVarsESO has maximum 256 columns.
This is due to the - now completely outdated - inner limitations of Excel. Indeed, before Excel 2007, you could only have 256 columns.
|                 | Max. Rows | Max. Columns |
| Excel 365*      | 1,048,576 | 16,384       |
| Excel 2013      | 1,048,576 | 16,384       |
| Excel 2010      | 1,048,576 | 16,384       |
| Excel 2007      | 1,048,576 | 16,384       |
| Excel 2003      | 65,536    | 256          |
| Excel 2002 (XP) | 65,536    | 256          |
| Excel 2000      | 65,536    | 256          |
| Excel 97        | 65,536    | 256          |
| Excel 95        | 16,384    | 256          |
| Excel 5         | 16,384    | 256          |
(Source of table: superuser)
Solution:
In EP-Launch, Go the options, and find "Allow More Than 250 Columns" and check the box (I believe it sits under "Miscellaneous" according to the source code).
Side notes:
Problem cause:
There is an option in EP-Launch, I believe disabled by default, to allow more than 250 columns. In reality, it's actually 255 variables + one column row header that gives 256 columns. So by default the CSV output generated by ReadVarsESO has maximum 256 columns.
Solution:
Side notes:
