As far as I know the only way is to use "External natural vented cavity" objects You need to modify the idf file manually (or perhaps if you are able to produce a measure to do it)
As far as I know the only way is to use "External natural vented cavity" objects You need to modify the idf file manually (or perhaps perhups if you are able to produce a measure mesure to do it)it)
