In OS the very bottom tab on the left shows the results. The second result report is Annual Overview. Click on that and then click on End Use - View Table. Your HVAC energy use would be the sum of the heating, cooling, fans, pumps, heat rejection, humidification, etc that is used in your HVAC system. For monthly consumption you can do the same thing with the Monthly Overview results. image description
