EnergyPlus solves the performance curves at rated conditions and uses the multipliers accordingly. Check out page 807 in the Engineering Reference. I don't know if that's the only thing that's causing your numbers to be off, but I suspect that's at least part of it. Note that 'TotCapTempModFac' should be solved at rated conditions, not 'TestB'.
EnergyPlus solves the performance curves at rated rating conditions and uses the multipliers accordingly. Check out page 807 in the Engineering Reference. I don't know if that's the only thing that's causing your numbers to be off, but I suspect that's at least part of it. Note that 'TotCapTempModFac' should be solved at rated conditions, not 'TestB'.it.
