You need to look at the Input/Output reference guide for Zone
The cooling/heating "loads" are the following two variables:
HVAC,Average,Zone Air System Sensible Heating Rate [W]
HVAC,Average,Zone Air System Sensible Cooling Rate [W]
You'll note that we're talking here about sensible cooling.
If you want to get total cooling, you need to look at the HVAC system. If you don't have a specific HVAC system designed in your model, you should put a ZoneHVACIdealLoadsSystem and report the following variables (especially the last one which is the sum of the first two):
HVAC,Average,Zone Ideal Loads Zone Sensible Cooling Rate [W]
HVAC,Average,Zone Ideal Loads Zone Latent Cooling Rate [W]
HVAC,Average,Zone Ideal Loads Zone Total Cooling Rate [W]
If this is for sizing purposes, it's worth also noting is that you should really use the Sizing:Zone objects for this. You'll get a epluszsz.csv file where you'll have a row for each zone where you have a Sizing:Zone, and that specifies the load (see output description)
