If you have anything set to autosize then you will need to have design days in your model. If not, then generally you could not have them, although I do believe OpenStudio still requires design days even if they are not used because everything is hard sized, unless you just have ideal air loads.
If you are planning to sweep across locations are you going to manually re-size equipment or do you expect a one size fits all solution?
