Using Popen with multiple args and piping the output to display the actual error message
Since subprocess.check_call shouldn't have stdout and stderr pipes, you should use Popeninstead.
See the subprocess documentation especially check_call and for Popen.
import subprocess
eplus_path = '/Applications/EnergyPlus-8-6-0/energyplus'
eplus_file = '5ZoneAirCooled.idf'
weather_file = 'USA_CO_Golden-NREL.724666_TMY3.epw'
df = subprocess.Popen([eplus_path, "-w", weather_file, eplus_file], stdout=subprocess.PIPE)
output, err = df.communicate()
print(output.decode('utf-8'))
if not err is None:
    print(err.decode('utf-8'))
In a case where it goes well, I'll see something that starts with:
EnergyPlus Starting
EnergyPlus, Version 8.6.0-198c6a3cff, YMD=2017.01.17 23:46
Processing Data Dictionary
Processing Input File
... etc
In a case where for example I don't have the right idf file in my folder:
ERROR: Could not find input data file: /Users/julien/Software/RunningEPlusFromPython/2ZoneAirCooled.idf.
Type 'energyplus --help' for usage.
Shlex as helper to parse a command
Note that the subprocess calls expects a list of arguments. Using shlex to decompose a command line (that you can try directly in a terminal/cmd prompt) can be useful:
In [1]:
import shlex
command_line = '{eplus_path} -w {weather_file} {eplus_file}'.format(eplus_path= eplus_path, weather_file=weather_file, eplus_file=eplus_file)
print(command_line)
Out [1]:
/Applications/EnergyPlus-8-6-0/energyplus -w USA_CO_Golden-NREL.724666_TMY3.epw 5ZoneAirCooled.idf
In [2]: shlex.split(command_line)
Out[2]: ['/Applications/EnergyPlus-8-6-0/energyplus',
         '-w',
         'USA_CO_Golden-NREL.724666_TMY3.epw',
         '5ZoneAirCooled.idf']
Seeing the EnergyPlus simulation output in real time as the simulation runs
If you need to do this, here's how:
import subprocess
# If python 2.7: `from __future__ import print_function`
popen = subprocess.Popen([eplus_path, "-w", weather_file, eplus_file],
                         stdout=subprocess.PIPE, universal_newlines=True)
# Might need to use `#for stdout_line in iter(popen.stdout.readline, ""):` instead in python 2.7
for stdout_line in popen.stdout:
    print(stdout_line)
popen.stdout.close()
return_code = popen.wait()
if return_code:
    raise subprocess.CalledProcessError(return_code, popen.args)
Side note
From the docs on the energyplus CLI (command line interface), if you don't supply -w weather_file_path it searches for in.epw in the current directory (where it's called from). So a quick fix would be to make sure that your weather file is there an named in.epw. Just saying.
import subprocess
if not err is None:
EnergyPlus Starting
... etc
In [1]:
import shlex
print(command_line)
Out [1]:
         '-w',
import subprocess
    print(stdout_line)
if return_code:
Side note
import subprocess
if not err is None:
EnergyPlus Starting
... etc
In [1]:
import shlex
print(command_line)
Out [1]:
         '-w',
import subprocess
    print(stdout_line)
if return_code:
import subprocess
if not err is None:
EnergyPlus Starting
... etc
In [1]:
import shlex
print(command_line)
Out [1]:
         '-w',
See the instead (see subprocess documentation especially check_calldocumentation and for Popen.)
import subprocess
if not err is None:
EnergyPlus Starting
... etc
Since subprocess.check_call shouldn't have stdout and stderr pipes, piped, you should use Popeninstead (see subprocess documentation)instead.
import subprocess subprocess
eplus_path = '/Applications/EnergyPlus-8-6-0/energyplus' eplus_file = '5ZoneAirCooled.idf' weather_file = 'USA_CO_Golden-NREL.724666_TMY3.epw' 'USA_CO_Golden-NREL.724666_TMY3.epw'
output, err = df.communicate() print(output.decode('utf-8')) if not err is None: print(err.decode('utf-8'))
In a case where it goes well, I'll see something that starts with:print(err.decode('utf-8'))
EnergyPlus Starting
... etc
