Sounds like the economizer is providing sufficient cooling to meet the cooling load and then some. In this case, the zone heating temperature set point will be maintained. Check the outdoor air flow rate, mixed air temperature, and cooling/heating coil outlet air set point temperatures with respect to each coils inlet air temperature. I would suspect the heating coil is active at this time since the zone heating temperature is maintained. If this is not the case, check the set point managers serving each coil to see what set point temperatures are placed at each coil's outlet node.
