Partially an OS bug, although in my opinion it's a poorly written EnergyPlus error. Pretty sure you can't use AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction
with only one coil. Based on the way the error checking is written it is expecting to see an object there as there isn't a 'blank' case written. The rest of the code for that object is definitely written for both coils being present. The OS bug comes into play because the configuration for the object labeled 'HW Two Pipe Induction Terminal' isn't valid, again, because of the missing CHW coil.
Solution: If you really want a reheat induction terminal I'd just use a configuration with a CHW coil that has the availability set to always off.
