You might not have the "OpenStudio results" html page available because in OS 2.0.0 it isn't added by default, you have to manually add it by going to the Measures tab. As far as the display problem, it should be discussed on the github issue, but you might want to open the eplustbl.htm
directly in your web browser of choice as it will more than likely display just fine there (I suspect it's an OS problem - on windows, not on mac - and not an E+ one)
And no, there's no scan for tools anymore, it isn't needed. See this commit (diffed) that removed it
