The totalEnergy economic tariff variable should represent the entire amount of energy, during each month, for the facility assuming that the Output Meter Name field is Electricity:Facility. If you are using the Time of Use Period Schedule Name field to define different time of use periods, than the sum of each period (peakEnergy + shoulderEnergy + offPeakEnergy + midPeakEnergy) should be the same as the totalEnergy.
