model.runPeriod returns an optional type. To get the actual RunPeriod object you first need to check if the object is 'empty' (see the 'OpenStudio Measures and the boost::optional Type' section here). So for instance:
run = model.runPeriod.get if not model.runPeriod.empty?
will return an object of class OpenStudio::Model::RunPeriod if the osm has a run period object, or false if it doesn't.
Once you get the actual object, running the methods method will show the full list of methods for that object.
model.runPeriod.emtpy?
model.runPeriod returns an optional type. To get the actual RunPeriod object you first need to check if the object is 'empty' (see the 'OpenStudio Measures and the boost::optional Type' section here). . So for instance:
run = model.runPeriod.get if not model.runPeriod.emtpy?
model.runPeriod returns an optional optional type. To get the actual RunPeriod object you first need to check if the object is 'empty' (see the 'OpenStudio Measures and the boost::optional Type' section here. So for instance:
Once you get the actual object, running the methods method will show the full list of methods for that object.object.
