Hi @Waseem, it is most likely that this surface is being altered by SketchUp when you open the file in the SketchUp plug-in. When you open the file do you see any messages about surfaces that can't be drawn? Try opening the Ruby console in SketchUp before importing the IDF and see if any messages show up there.
Dan
