you could always run your code bit by bit in interactive ruby. Or save parts of it to a ruby script and run that from terminal. For interactive ruby, irb in the command terminal will take you into ruby. Then:
require 'openstudio'
# Helper to load a model in one line
def osload(path)
translator = OpenStudio::OSVersion::VersionTranslator.new
ospath = OpenStudio::Path.new(path)
model = translator.loadModel(ospath)
if model.empty?
raise "Path '#{path}' is not a valid path to an OpenStudio Model. Did you remember to use backlashes / instead of forward slashes \ ?"
else
model = model.get
end
return model
end
load_path = "C:/Users/me/path/to/your/model/with/backslashes.osm"
model = osload(load_path)
and then do whatever modeling you want
