The main output for the UtilityCost:Tariff object is in the tabular report (usually HTML) and are in the Tariff Report and the Economics Results Summary Report. The Tariff Report shows results on a monthly basis. These reports should be automatically generated when the UtilityCost:Tariff object is present. An example of this is shown in the 5ZoneEconomicsTariffAndLifeCycleCosts.idf example file. No output variables are currently used with the tariff calculations which are mostly performed after the simulation is complete. For real time pricing rates there has been a request to add an output variable.
